coolmom42
Oct 04, 2020Explorer II
carringb wrote:
I used to use reflectix to keep the trailer cool when boon-docking in the high dessert. I came back to the trailer one time, and the sealant on the bedroom, which didn't get any shade that day, was melting. Luckily I only lost some trim, and as soon as I removed the reflectix, the sealant started to set back up before the glass fell out.
So... I still use it all winter, but I'm selective in the summer. I won't use in anymore in very hot weather if the window will be in direct sun all day.
White vinyl on the outside would probably lower the temps enough so it won't be a problem. A window would be small enough to cover with sign-vinyl, which is much cheaper than automotive-vinyl, and you might be able to pick up some remnants for very cheap at a sign shop.
This is a very good suggestion. I will be going by a sign shop tomorrow so will stop and ask.
38,782 PostsLatest Activity: Sep 10, 2026
