dicknellen
Oct 05, 2020Explorer II
IAMICHABOD wrote:
I have used it for more than 6 years in the window of the overhead bunk,to keep the heat down and keep from sun bleaching the curtains,it faces east when stored here at home.
There has not been any downside to this or any problems. I also use it in the rear and side windows while stored here at home and also camping when needed.
The nice thing I like about it over the solid,which I tried,if you want to see out all you have to do is take it down and roll it up for easy storage. Not so on the solid boards,always a storage problem,I found it was a real pain.
Same here, only problem I know of is if you have dual pane windows. My local glass company said not to use it on dual pane home windows. He said they get a lot of business from fixing dual pane home windows because of this causing heat build up. I took it out of the few dual pane home I was using it in.
38,782 PostsLatest Activity: Sep 10, 2026
