wopachop
Oct 06, 2020Explorer
You can peel the foil off the white foam boards at home depot. Cut it with accuracy and it will hold itself tight in there.
Get a piece of paper. Hold it against the window. Use a pencil to scratch the rounded corner shape. Then cut along the pencil line and use that template to cut the foam board.
38,782 PostsLatest Activity: Sep 10, 2026
