dougrainer
Jan 14, 2023Nomad
COLD below 20 degrees affects the operation of the COOLING UNIT ammonia mixture. Turning on the LAT(if installed) does NOT have any affect on extreme cold weather operation. It is best to just install a 40 watt incandescent light bulb in the rear outside of the refer. Of course, this assumes you will be able to plug in to 120 volts while staying in the Hotel. I always advise AGAINST blocking the outside air door intakes. Out of sight and out of mind mentality takes over and if you forget to open up the blocked doors when traveling to warmer climates, you can ruin a cooling unit. Doug
38,782 PostsLatest Activity: Sep 02, 2026
