- 10forty2Explorer
John Wayne wrote:
do you have a gfi that needs to be reset. The outside refrigerator. plug should be connected to a gfi.
X2 - Happened to me a few weeks ago when washing the rig. I left her plugged into shore power to keep the A/Cs running and apparently I shot water into the refer's vent, hitting the electrical outlet and tripping the gfi. Reset the gif outlet upstream, and everything is back to working. - wa8yxmExplorer IIII have a dometic Fridge
You have a circuit breaker in your breaker box Visually inspect it
Now go outside and you will find a plug and outlet in the outside compartment behind the fridge. Unplug and test with a test light or other electrical device (Fan for example)
on Dometics there is a circuit board with the old 3-ag Glass fuses bottom center
Additional fuses in the black box to the left DO NOT KNOW which ones are 120vac
And the board someone else mentioned. also that black box
If the board is bad Consider Dinosaur boards. they are superior in my opinion . - ArchHoaglandExplorerMake and model of refrigerator would help.
- Fleet_ManExplorerWhen we had a similar problem, refrigerator would run on propane only, the problem turned out to be a bad converter/charger. Have you considered that?
- John_WayneExplorer IIdo you have a gfi that needs to be reset. The outside refrigerator. plug should be connected to a gfi.
- MountainAir05Explorer IIThe heating element also could be bad.
- tropical36Explorer
mcilvaniej wrote:
I have a 94 Rexhall Airbus, refrigerator worked fine when I plugged into electric 2 weeks ago, now it does not, just goes to gas. Does anyone know where the fuse is, if there is one. Thank You
Martha
12vdc is required for gas operation as well, so I'd be looking for a loss of 120vac power.
Be sure it's still plugged in in the back of the fridge, accessible from the outside panel. A meter or small appliance can be checked for power at the outlets there.
There could be a 120v fuse back there, inside a panel, so do take a look there, while you're at it.
Reset all breakers in the main panel.
Check the breakers on your inverter, if you have one. - IvylogExplorer IIIProbably on the control board assuming you have power to the 120V outlet.
38,763 PostsLatest Activity: Dec 05, 2025
