Busskipper
Nov 19, 2013Explorer
SteveAE wrote:
Gas absorption refrigerators can be damaged in cold weather. Norcold makes a cold weather kit for their products, or you can just put a low wattage light bulb in the back of the refrigerator compartment to warm it up a bit.
Steve
This is good advice -- your only concern should be if the temps stay below 10 degrees for a while, if that is the case add the light bulb.
Generally what happens is the Panel will shut down the refrigerator and need to be re-set. PIA so add the light and avoid the service call.
BOL,
