dougrainer
Nov 19, 2013Nomad
SteveAE wrote:
Gas absorption refrigerators can be damaged in cold weather. Norcold makes a cold weather kit for their products, or you can just put a low wattage light bulb in the back of the refrigerator compartment to warm it up a bit.
Steve
They cannot be damaged in cold weather.
WHAT CAN DAMAGE THEM IS BLOCKING OFF THE BACK VENT. NEVER BLOCK OFF THA BACK VENT. The refer needs air flow from bottom to top. You can partially block off, but install a light bulb or heat source to help them stay running. The ammonia mixture CANNOT freeze or be damaged. BELOW 20 degrees ambient, even with a heat source, you may have marginal or no cooling. Doug
