dougrainer
Nov 07, 2013Nomad
On any Norcold refer in the past 20 years, just disconnect the inside Temp thermistor plug and then run 24 hours. That will usually give you a good indication of the cooling of the refer. If it cools to specs but not with the thermistor plugged in, the odds are the Thermister is defective. A Defective Norcold Thermister will test (OHM test) OK, even tho it is bad. Doug
