daytripper63's avatar
daytripper63
Refrigerator warms up when driving
I have a Dometic NDA1402 side x side refrigerator and anytime I travel it gets warmer, even when we don't open it. It does not matter if it is running on propane or if I run it on the generator. It does not matter if it is hot weather or cold. I just drove 107 miles in 76 - 85 degree weather and when I left outside temp was 85 and the refrigerator side was 33 and the freezer was 1 degree, when I reached my destination the refrig was 44 and the freezer was 21 degrees
I am in the air conditioning business and I have two temp probes so I can measure temps without opening the doors.
The frig is installed in the slide out and has the vents at both top and bottom to the outside, it also has two fans in the back to help dissipate the heat and they are both working.
Does anyone else have this problem and if so has anyone figured out how to solve it.
