marbilupton's avatar
marbilupton
refrigerator won't come on
I forgot to switch my refrigerator back to A/C the last time I used it and left it on propane. The propane ran out and naturallly the refrigerator went out . Now it will not come on the A/C side. I get a "no co" code on the display. Any help on what to check will be appreciated.
  • What brand/model/ refrigerator is it?
    If a Norcold 1200 you can unplug it and then plug it in again. If that doesn't help you will need to pull the cover off the control panel and ground a pin.
    I just had to do that last month to clear the same problem.
