Goldencrazy
May 13, 2016Explorer
The advice here is good. Especially by not waiting until you are on fumes. I have found most travel centers have pretty good room around the gas pumps. And have an in and out exit. Drive in on the right and go between pumps and building and swing to end pump. You should have enough room and most fuel intakes are in the drivers side. Then straight out second exit. Take your time and don't be pressured. If you get in a spot where you need to backup then unhook. It isn't so bad. Good luck.
38,768 PostsLatest Activity: Nov 21, 2015
