Kalait
Jun 30, 2017Explorer
pauldub wrote:
You can possibly flat tow the Xterra if you get a driveline disconnect. The Xterra plus a trailer will likely be much too heavy, even the Xterra alone might be over the tow rating.
Please further explain, Nissan says I can not flat tow more than 10 miles without possible damage to my Differential, I plan to change the oil every 75,000 miles or as recommended. The driveshaft can be removed and replaced with the bolts replaced to the same nuts. This is a major part of the question, my Owners Manuel does not state yes/no on flat towing. I will be looking tomorrow on the possibility of removing the driveshaft. I will be marking the bolts with the shaft side for replacement.
