wa8yxm
Jan 18, 2016Explorer III
Now there are exceptions and I'll cover one or two of 'em but every expert, EVERY EXPERT I have heard from (And there have been a lot of them) say the same thing READ THE MANUAL.. Most modern engines are designed to run on REGULAR Gasoline and if this is the case paying for Mid Range or Premium is a waste of money.
HOWEVER.... Exception one.. At very high altitudes they lower the octane of Regular.. When I got gas at altitude the engine did not run well.. Switching to Mid Grade to maintain the minimum octane rating would likely have been a good idea and next time I'm in the mountains,, that is what I will do.
Exception two: This was a car, a 1997 with a carburetor not a modern computer controlled EFI job Turns out the factory carb was faulty.
I keep MPG records. Every fill up (Which reminds me I need to do a calc or 2) And that car got much better MPG on Mid-range... ENough to make it the best bargain.. It also did better after waxing, way better.
on the motor home.. Waxing.. Same result. Better MPG.. Way better.
