Bordercollie
Nov 14, 2020Explorer
Our experience with our 2004 Class C was that the roof AC unit, fridge, converter/charger, and fresh water pump and awning fabric all needed replacement around the 10 year old point. Tires older than 5 years old should be replaced for safety. House batteries usually need replacement every 5 years. The RV generator needs to be run frequently or it may need expensive service. RV brakes need periodic servicing for safety. The Ford engine and transmission are generally trouble free for many, many miles with periodic maintenance.
Most RV's only are driven some 5000 miles per year, some even less. Taking the above possibilities into account, you might come out ahead renting a motorhome if you don't foresee continuing the "hobby".
Otherwise, buying a newer used motorhome. around 3-4 years old, might be a better option. In any case, ask questions and get a prospective "buy" inspected by a pro truck mechanic and a trustworthy RV service shop and get an itemized list of repairs/upgrades needed with parts and labor estimates. Make sure that everything works properly. Sign up for emergency road service.
