trashguy
May 25, 2018Explorer II
chuckftboy wrote:
I see no issue with cutting the cord and putting ends on it. Extension cords have ends replaced every day with no issues. You might also install a twist lock receptacle in the wet bay and just use a cord with a twist lock end. a lot of coaches are setup this way.
Probably be what I end up doing. Most of these are 30amp units and the cord is so much smaller it's probably not as much an issue but that 50amp anaconda is for sure a pain and I will end up with a busted crapper drain or something.
38,778 PostsLatest Activity: Jun 07, 2026
