larry_cad
May 26, 2018Explorer II
Best improvement you can make is to replace the factory power cord with a good quality RUBBER cord. Factory cord is thermoplastic covered, is thick, and hard to coil. "SO" cord is durable and easy to coil and much smaller in diameter, and yet has the same wire gage, (#6) I did this with mine 10 years ago and it is perfect still today.
If you decide to install a twist lock receptacle, stick with Marinco brand. That is typically what is used on boats and high end motorhomes. It is durable and waterproof.
If you install a receptacle in the water bay, you can unplug your cord, coil it up and put it any where you want when not in use.
38,778 PostsLatest Activity: Jun 07, 2026
