duckiee
Jun 26, 2013Explorer
glamisorbust wrote:
What are the brakes doing? Pulsing, surging, squeaking, not working at all? Call orangewood RV in surprise, AZ. Talk to Jim, at the parts counter. He knows his stuff, and will answer any question you have. They can also look at your brakes or anything else problematic. I have had very good luck there. If they aren't close to you, they can at least point you in the right direction as to where to take it.
Tried to call Jim today. Guess he was busy. I left a message and he didn't get back to me. I kept looking for a mobile truck repair and after searching for a while I found one to take a look at my RV. He things that I might just need to bleed the brakes. So I will try that first and hope it not any worse than that. I found the guy on the internet. He is based here in Surprise. I can't think of the name right now, but he came out to the storage lot and fixed my tire. Looked at the RV. Told me about some leaks I have underneath. Gave me some advice and gave me a brake by not charging me! What a guy! In this heat he was crawling all around under my RV. I will certainly call him again if I need anything else done.
38,782 PostsLatest Activity: Sep 10, 2026
