msmith1199
Dec 20, 2015Explorer II
Belgique wrote:
We just installed Alure Ultra and did not remove the slides. A pro did the install for $1K labor. Fantastic job. Best $1K I ever spent.
Just curious, I was looking at installing this too, but per the manufacturer specs, you are only supposed to put this flooring in a location where the temperature can be maintained between 55 and 85 degrees. That's usually fine in most houses, but unless you live in your motorhome can you always make sure the interior temp stays in that range?
38,763 PostsLatest Activity: Dec 05, 2025
