Belgique
Dec 21, 2015Explorer
msmith1199 wrote:Belgique wrote:
We just installed Alure Ultra and did not remove the slides. A pro did the install for $1K labor. Fantastic job. Best $1K I ever spent.
Just curious, I was looking at installing this too, but per the manufacturer specs, you are only supposed to put this flooring in a location where the temperature can be maintained between 55 and 85 degrees. That's usually fine in most houses, but unless you live in your motorhome can you always make sure the interior temp stays in that range?
We chose Allure Ultra after reading many many reports from other folks here and on other sites. A huge majority never had any problems with temps out of the parameters. Maybe because Ultra floats so with proper expansion joints on the sides, it works? So far, we are very very happy with it.
38,763 PostsLatest Activity: Dec 05, 2025
