TimfmCTExplorerNov 30, 2014Removing a/c ceiling air return coverGood morning, I can not think of the name of the white cover on the ceiling that holds the air return filter. It also permits having the a/c or heat pump to be routed directly into the living ar...Show More
donn0128Explorer IINov 30, 2014Depending on AC brand there should be a screw near each corner. Remove them and it should drop off.
Related ContentStaple RemovalEasy way to remove slide topper?Bigfoot carpeted ceilings -clean, remove, cover?Ceiling Stain RemovalReturn to AngelFireNM...
