TimfmCTExplorerNov 30, 2014Removing a/c ceiling air return coverGood morning, I can not think of the name of the white cover on the ceiling that holds the air return filter. It also permits having the a/c or heat pump to be routed directly into the living ar...Show More
dougrainerNomadNov 30, 2014Use a knife or small screwdriver to "pop" that cover off, you will then see the screw underneath. Doug
Related ContentStaple RemovalEasy way to remove slide topper?Bigfoot carpeted ceilings -clean, remove, cover?Ceiling Stain RemovalReturn to AngelFireNM...
