ezgoinExplorerApr 06, 2015Removing Atwood water heater plug photo addedWhat's the easiest way to remove a Atwood water heater plug? I can barely fit my adjustable wrench onto the plug and can only turn it less than 1/8 of a turn at a time due to tight access. Curi...Show More
mccsixExplorerApr 08, 2015Ck the wire for continuity to ground or voltage, then remove the clamp do your plug thing and re-install the clamp with shorter bolts.
Related ContentAtwood water heater problemStaple RemovalAtwood water heater problematwood GHC6A-10E water heaterAtwood hot water heater
