jwmII
Apr 08, 2015Explorer
ezgoin wrote:
Here's my issue. Bolts on clamp are too long. What is this wire that's clamped on here?
That clamp is an electrical ground wire clamp. If it is on the gas line ,Remove it and seek another area(like on the frame) to ground the wire. That will allow you access to the drain plug when you remove the clamp from that gas line. Using a dissimilar metal plug from what the heater tank is made of will setup electrolysis and erode the aluminum heater tank and could even******up the plug and threads so bad that you cannot remove it.
