ezgoinExplorerApr 06, 2015Removing Atwood water heater plug photo addedWhat's the easiest way to remove a Atwood water heater plug? I can barely fit my adjustable wrench onto the plug and can only turn it less than 1/8 of a turn at a time due to tight access. Curi...Show More
oldkeywest91ExplorerApr 08, 2015the black wire is a ground wire to the copper tubing.if it helps you can just loosen the screws and turn the clap out of your way.
Related ContentAtwood water heater problemStaple RemovalAtwood water heater problematwood GHC6A-10E water heaterAtwood hot water heater
