Executive wrote:
msmith1199 wrote:
Executive wrote:
Make sure they're not LEFT hand threads!
Scott's "trick" has been used for years and works better than anything else. At the very least, get a can of penetrating oil, I like PB Blaster, (Home Depot/Lowes/Napa). Shoot if well and let it sit overnight. Put the correct size socket on it, rap it a couple times with a mallet and then try getting it off. An impact wrench should be a LAST resort!
Just out of curiousity, when was the last time you checked this fluid reservoir? It shouldn't be that tight in only a years time right..:W....Dennis
Why would there be left hand threads on something like this? Made in England?
Who knows? My pop-up had left hand threads on ONE wheel only. The other was right handed. Drove me nuts until I figured it out..:S..Dennis
The only time I've ever seen left handed threads is on something that spins (like a wheel on a pop-up) where the spin may otherwise unwind the bolt. However I don't know why they would put that on a pop-up unless there was only one big lug nut holding on the wheel, versus five lugs?
