GeocritterExplorerFeb 23, 2014Removing gray water tank insulationIn the next month or so I need to replace my gray water tank because of a huge unrepairable crack in the bottom. The current 40 gallon tank is mounted so that it extends half ways into a heated unders...Show More
jhilleyExplorerFeb 24, 2014This scraper set from Harbor Freight should help you out, especially the long handled scraper4 Piece Scraper Set
Related ContentReplace insulation inside heater column.Staple RemovalRemodel insulationWater PumpEasy way to remove slide topper?
