Sloop_Smitten
Feb 10, 2014Explorer
This is how to remove the one on my 1991. I would suspect yours is the same or similar.
Remove the screws and detach the armrest.
Remove two nuts holding the door handle and remove the handle and trim.
Remove four speaker screws and detach the grille.
Remove the screw holding the window regulator handle and remove the handle. (If you have electric handle or locks you would disconnect the appropriate connectors or screws.)
Carefully pry the clips on the sides and bottom of the panel from the door.
Raise up on the panel to detach it from the window ledge and remove the panel.
