HSE2LT
Feb 11, 2014Explorer
I have a 1997 so doors may be similar. On mine there are no clips. Window crank is held on with allen head screw, remove. Lower corner of door, small plastic plug, remove, should be philips head screw, remove. Upper corner near mirror, mine has a philips head screw, remove. Mine does not have clips. After removing these attachments, slide panel up about 2 inches, and remove. There are hooks on panel that fit into holes on door. I don't remember if there are screws near armrest or not. Took a fast look (12 degrees outside) at mine in driveway didn't see any.
