dms1
Oct 25, 2016Explorer
If they are just vinyl decals, you should be able to heat them up with a heat gun and gently peel them off. If that doesent work the Vinyl sigh industry sells special spray on liquids that help with the removal as well as attachments for a 4.5 " grinder that will help remove the stickers.
https://www.amazon.com/Whizzy-Wheel-Pinstripe-Rubber-Eraser/dp/B00FJF0O2K
If on glass, use a razor blade to scrape off.
38,766 PostsLatest Activity: Jan 10, 2026
