Oldtymeflyr
Jan 28, 2022Explorer
We removed decals that were in bad shape. Not that many. It worked out well.
I have seen MH with the decals removed, Its okay, nothing to write home about. If you like it that way then fine. It would give a clean look, if the next owner really wants decals, they have a clean rig to work on.
We found that the rubber eraser worked well. Then some 3M Adhesive remover scraped with a plastic gift card, the flexibility of the card works well on fiberglass.
To clean up the remaining adhesive, discoloration, and general oxidation, compounding with an appropriate liquid cleaner is necessary. I use a number of products, rubbing compound, 3M Perfect-It, and Meguires 67, which I use the most.
Use a rotary buffing machine on fiberglass, I find that the orbitals do not work nearly as well. Gel Coat on fiberglass is different than paint. Get the speed up and watch the heat carefully, keep the machine moving. Then to clean things up and make the MH look good, I use Meguires 67 which has a wax base as well and it does look good when done. I also use Fast Finish by Meguires, this is an easy to use product that produces a good result. I am experimenting with Meguires Ceramic Hybrid product, but do not feel comfortable using it on the MH with out more experience with it. If you do not have a good buffing machine, it will take a lot longer and be more difficult to finish the removal. Best.
38,782 PostsLatest Activity: Sep 10, 2026
