p0oches's avatar
p0oches
Removing old Diamond Shield??
It's 10 years old, discolored, and cracked. I'm able to remove the shield using Scraperite plastic razor blades, in sunlight. Have not tried a hair dryer yet for fear of damaging the clear coat. Bigger problem is removing the adhesive, which takes much longer. I apply 3M Adhesive Remover, and scrape the adhesive into globs (which stick to everything) with the plastic blade. I then rub off the residue with more 3M stuff. This may take weeks, maybe months!
Is there an easier way without taking off clear coat?
Thanks for any tips.
....Doug 2003 Journey DL, 36GD, 330 Cat
  • I just got an estimate from local body shop to remove mine, which is in same condition, appox $300, sounds like i got a good deal, if they stay within estimate. I have removed part of it ,but removing the glue and lower section of front cap , just became to intensive. Good luck.
