p0oches
May 05, 2013Explorer
Removing old Diamond Shield??
It's 10 years old, discolored, and cracked. I'm able to remove the shield using Scraperite plastic razor blades, in sunlight. Have not tried a hair dryer yet for fear of damaging the clear coat. Bigger problem is removing the adhesive, which takes much longer. I apply 3M Adhesive Remover, and scrape the adhesive into globs (which stick to everything) with the plastic blade. I then rub off the residue with more 3M stuff. This may take weeks, maybe months!
Is there an easier way without taking off clear coat?
Thanks for any tips.
....Doug 2003 Journey DL, 36GD, 330 Cat
