Smitty77
Jul 05, 2015Explorer
Thanks! I should have added that the leak is on the passenger side of the engine, towards the front about 4-5" towards the rear of the engine from where the lift pump is located. I had found one leak, a 7/16" tube going into a right angle coupling, from the same area. A compression nut needed snugging up about 1/3-1/2 turns, stopped that leak. Added 2 gallons of 50/50 Final Charge to the radiator tank reservoir. And thought I had everything fixed:)!
A few days later, the puddle was still not dry under the coach. So went back under and found moisture running down from the top side of the block, again a bit back towards the rear of the engine
lift pump. Squirted everything off well with a stream of water from a bottle. Wiped all that I could reach down with rags. Fire up the engine and let it idle for 35 mins at 1000 RPM, silverleaf showed 154 temp. Got back out and under, and all looked good. Again, thought I was good to go...
Next day, got out to take another look to be sure, and same trail of coolant coming down from the same location. Using a mirror on a stick, could not determine the source.
I've asked over on the IRV2 Cummins Forum, if anyone knows of any potential sources from the passenger side up towards the top side of the engine. Looking over all the manuals I have, I can't see any coolant sources that come from that area. But, maybe missed them. Will tear out the bed and closest to get access from above, if anyone can think of a potential source.
And of course, even though I see it leaking down the block, from a 3-4" recess like ledge, from the passenger side about about 1/3 from the front of the engine. It does not mean that is where the leak is, fluid will travel...
I'll check out Smith's. We stayed over a few more days here in Sparks/Reno to get this resolved, before heading East on Hwy 50. Everyone was closed down for the 4th of July on Friday, when I determined I should get it looked at with a dye leak test. (I did not mentioned, I had a mobile gent come and look things over, and he thought the compression nut leak had left enough fluid blown around the engine while driving, and into the conduits that protect with wire harnesses - that I was just seeing residual flow. That is why when he left, I went ahead with cleaning the block the best I could with a full spray bottle of water, and ran the engine for 35 mins to let things sort of bake off.)
Have not posted for awhile, and I start back up with a long thread:)!
Best to all,
Smitty
Best to all,
Smitty
