klutchdust
Oct 12, 2019Explorer II
pnichols wrote:Jayco-noslide wrote:
We like our 15 year old 30 ft. Class C we've had for 7 years. Reliability has always been up and down. We had a pretty good couple of years of repair costs we could live with but now we're discouraged and don't know what to do. Many costs this past year; some routine and expected, some not. Must have totaled 7 to $8000 and today, after $300 dollars of work, I'm told that I need a differential bearing which this shop can't do which will cost thousands; not hundreds. Only has 67000 miles. We're reluctantly considering downsizing to an older used Class B, like a Roadtrek but seems like we would have to repair our present one to sell it. I'm not asking for an answer; just venting. Oh, spending over $30000 for a replacement is out of the question. Thanks for "listening"
I'm guessing that your Class C is probably (not a Super C) based on a Ford E350 or E450 chassis - in which parts and mechanics are available everywhere.
If it is ... wouldn't it be least expensive to merely have a used (from a junkyard, reclamation yard, etc.) whole rear axle and differential - as a complete assembly - installed to replace the original one?
Probably way less labor than messing with disassembling an installed differential merely to replace it's bearings.
And the cost to locate, remove and replace the entire unit?
A qualified competent mechanic can easily replace the bearings and not for thousands, that’s just ridiculous.
What exactly are the symptoms.
38,782 PostsLatest Activity: Aug 30, 2026
