RustyMacIntosh wrote:
I saw the cops rousting out a nice pusher diesel motorhome parked way out at the outer limit of the parking lot at a Walmart.....Wallys used to be the place to spend the night, but in Cal the homeless have squatted to the degree I guess Wally has put the kibosh on staying overnight.
I found hotels to be the best place to hide out in. Large hotels where you can get lost in the shuffle. You can get a nites rest, sponge off their WIFI and get a breakfast too....
On my Bounder, the only part I have never been able to figure out is the momentary water pump switches. I get nada at the pump. I jumped the pump with wires leading into the bathroom where I have a small riding lawn mower battery. If I need water, we connect to the battery,
I did change that intelligent box above the pump, the interesting thing is the neg was live and the pos was cold when testing the power to the box.
The red was cold, but the white with red stripe noted as NEG on the little box, was live...had power there.
Rusty, if one of the momentary switches is stuck in the closed position, the water pump controller will not change state.
SchematicRichard
