MountainAir05
May 28, 2018Explorer II
Two 2200i Honda with the connect cable will give you 30 amp, but you are looking at Close to or over $2000. 30 amps is only one (1) 120 volt live leg. It is one 120 live leg and one center ground and one neutral.
The comment you stated that to separate the 240 in two 120 will not work with out jerry rigging it. A 240 Volt plug in is 120 on each slant leg and ground on the center. You 120 volt AC and anything else would not like 120v leg and another 120 volt on what is suppose to be neutral and a Center ground.
I am in the process of helping a friend to replacing AC and other 120 volt appliance that just had the same thing done. They smoke. So far two AC, Microwave. TVs and not sure on the Charger yet . Not sure if it feed back into the engine computer and alternator. I am sure you will get other suggestions.
38,769 PostsLatest Activity: Mar 31, 2026
