colonelcorto
May 28, 2018Explorer
MountainAir05 wrote:
Two 2200i Honda with the connect cable will give you 30 amp, but you are looking at Close to or over $2000. 30 amps is only one (1) 120 volt live leg. It is one 120 live leg and one ground and one neut.
The comment you stated that to separate the 240 in two 120 will not work with out jerry rigging it. A 240 Volt plug in is 120 on each slant leg and ground on the center. You 120 volt AC and anything else would not like 120v leg and another 120 volt on what is suppose to be ground.
I am in the process of helping a friend to replacing AC and other 120 volt appliance that just had the same thing done. They smoke. So far two AC, Microwave. TVs and not sure on the Charger yet . Not sure if it feed back into the engine computer and alternator. I am sure you will get other suggestions.
I think you may have misunderstood me. There are two separate input lines going to the transfer switch from the current gender. Each line contains its own hot, neutral, and ground. Both lines happen to be energized by one 120volt generator. I’m saying split the 240 and apply a 120 volt leg to each of the two inputs.
38,769 PostsLatest Activity: Mar 31, 2026
