MrWizard
May 28, 2018Moderator
to use the 240v option, it must be "4" wire, (2) HOTS, plus neutral, plus ground
many of us have used a 3000-4000w generator with the shore cord plugged in via 30amp RV plug,
just can't run 2 A/C units at the same time
i think your biggest problem is going to be heat, IF you confine the generator to inside the oem space, plus fuel capacity, and you won't be able to use it while moving
38,769 PostsLatest Activity: Mar 31, 2026
