wildmanbaker
Jun 03, 2018Explorer
I believe there is a point that is being missed here. The 240 volts is two legs of 120 volts, but each is 180 degrees out of phase with each other, and a common ground. To get this to work, you would need a 50 amp service in the MH which has to separate supply bars in it. Without this, you would be looking at most of the electronics being cooked inside the MH.
38,769 PostsLatest Activity: Mar 31, 2026
