wa8yxm
Jun 04, 2018Explorer III
IF you want a "Road" generator.. YOu might re-locate your power inlet to the REAR of the RV and put a cargo tray on a dual hitch adapter..
A "rise/drop" type hitch adapter doubles as the Drop (most likely) hitch adapter for your towed car and a 2nd 2" receiver ABOVE that. Make sure it is high enough and you mount a Cargo Tray (Harbor Freight, CW, Most Bigger RV places) and attach the portable generator there, Fully open air, and make sure exhaust points to the rear (Away from RV) then simply plug in
Do use locks to secure.
DO NOT run in a campground Even if power is lost (i've had to use my ONAN on site a few times due to lack of "Shore" power.. Little storm (Hurricane Matthew) for example, was one such case.
38,769 PostsLatest Activity: Mar 31, 2026
