Bird_Freak
Sep 16, 2014Explorer II
Also what seal? You have the shaft seal from the column and the shaft for the pitman arm. Top plate could be a gasket or a O ring. If lower shaft seal for pitman arm before I replaced I would have someone rock steering back and forth while watching shaft for any side movement. If you have side movement the bushing is worn and you should replace box.
38,766 PostsLatest Activity: Jan 10, 2026
