Jsejmz09 wrote:
Proof of Concept:
To make the genny fit I first removed the gas tank. And installed a low volume electric fuel pump. Then I wired the genny into the coach. (my shore power connects in plug in a different bay)
I added two vents to the door a 12x12 and a 8x8. Then I placed 'Temporary" a box fan to the open bottom sucking out. So far after 1 hour my compartment temp has risen 3 degrees above the outside temperature
I don't know how to post photos...
Curious. What is the brNd and output of the replacement vs the output of the original?
