rk911
May 21, 2013Explorer
Commerce wrote:
I have a 2004 Tiffin Phaeton that has a small dual pane window on the lower part of the entry door. The lawn maintenance crew at the last park I stayed in must have kicked up a rock and busted the outer pane because it is now shattered looking and I need to replace it.
Does anyone have a suggestion on where I could find one of these windows and can just the outer pane be replaced or do I have to buy the whole window unit frame and all ?
Thanks for any suggestions you have !
we had several fogged dual pane windows in our MH that needed to be re-sealed. the work was done by Suncoast Designers in Florida. we were very satisfied with the cost and workmanship.
I bring this up realizing that your window is broken, not fogged because if Suncoast had been unable to re-seal any of our windows they had the ability to cut new pieces of glass. you might give them a call and see if they can ship a piece to you.
38,766 PostsLatest Activity: Jan 10, 2026
