mkguitar's avatar
mkguitar
Replacement gas detectors- what do I want?
Detectors in the van are old-
I have a smoke detector mounted on the ceiling- that's easy, I'll get a home style.
I have a CO detector mounted up over the side door
and a Safe T alert gas detector mounted near the floor by the furnace.
( I see combo gas/ CO )
Suggests for replacement- considerations?
Thanks, Mike
  • A few things to keep in mind when replacing CO detectors. Those intended for home application are quite different from those designed for RVs. One major difference is the range of operating temperatures (where you will actually be protected). Home units have a narrow range typical for a home, RV units have a much wider operating range as expected in a RV. You have to check the small print in the technical specifications of the unit you are considering. There is also a difference in tolerance to shock and vibrations (home units are not tested) and to operating voltage as a standard RV unit is fed from the coach battery (from high charging voltage to low discharged battery).
    I went through the research when my CO detector went past its expiration date. I used a battery operated home unit to have some protection until I could find a proper RV unit (not cheap by any mean and hard to find compared to the home unit).
  • Thanks- I was wondering about the combo gas/co detector and mounting height
    gas heavier than air...but I think the CO is soluable/ same density as air and evenly distributed.
    MTI safe T alert says 4 to 20 " off the floor for their combo unit.
    I do like hardwired into 12 volt for the gas/CO.
    some other CO makers say that mounting location high/low/ceiling doesn't really factor...but to stay away from corners due to stangnant air flow
    Mike
  • Hi,
    There are two basic types or styles of smoke detectors. One is ultra sensitive to smoke, and it is ion type. The other is photo type, and requires more smoke to set them off, but will not likely be set off by a toaster set to dark bread.
    Photo detectors use a red LED and photo receiver, when there is enough smoke to interrupt the light, then it goes off. IT is suitable for a RV, because the smoke detector will be within about 10 feet of the stove or cooking device. It just will not go off due to the engine running, or something like that.
    CO detector can be the home style, but the battery can go dead while the RV is in storage, and you will not know it because nobody can hear it. Most RV's have a 12 volt system with inputs from both the engine and coach batteries.
    I would do a online search for 12 volt CO detectors, and hopefully find one the same size.
    Good luck,
    Fred.
  • You do NOT want a combo gas/co........they have different mounting requirements due to density of the element.
    Now if you meant SMOKE/CO ...then OK
    That comb unit can be mounted on wall 1 foot down from ceiling and function quike well
    LP Detector needs to be at floor level
    Battery operated are good. Just get into routine of changing batteries like July 4th and Dec 25th cause us AZs don't do the clock changing routine :B
    Brand.........basically all the same. Sensor/alarm...rest is just bells/whisltes
  • I can't recommend exactly, but I can tell you a few things to watch for, as you get advice.
    I was in the same situation, and decided to move quickly, to avoid forgetting and being sorry later. Lots of affordable options for the smoke detector. I puzzled over the CO and gas choices on the RV supply websites. They all seemed expensive, but at least I could get replacements for my current built-in models. It was a while before it dawned on me that there would be non-RV applications and availability, so I then quickly picked up a CO detector at a drug store on my second trip, for a very reasonably price less than $25. Home Depot has several affordable models also. What I have not been able to figure yet, and I will watch here for answers, is why I can find $25 models and $90 models where I cannot tell much difference. Not sure if price equals reliability and quality or not. But if you are like me, you want reliability for your safety, but since there are other RV goodies to shop for, you don't want to throw money away. If I find something better than my drug store CO detector for the RV (which is a good brand, and not a piece of junk), then I will move that into my house and get the replacement model for the RV.
    Good Luck
