mlts22 wrote:
klutchdust wrote:
Also a tank manufacturer in Tustin Ca. who makes and has just about every tank size imaginable for RV's and boats. Replacing it shouldn't be too difficult.
Use quality connectors, I used Pex in my trailer I built from Scratch, and never had a leak in the 7 years i owned it and I installed all the tanks and water lines.
What type of connectors are decent quality? I'm curious since I have been putting off some plumbing work in my rig, as a crimp connector worked loose, so am considering Flair-It fittings.
Yes, excellent choice. That is what i used. i could pressure up my system and return days later and the pressure was maintained ensuring a tight fit. Be sure the tubing is
inserted completely in the fitting and tighten accordingly. I have had to remove some fittings once and they sealed fine after that. There is also a new clamping tool
with steel rings you can use for piping, if you purchase that be sure to use the ratcheting tool they recommend. Be forewarned that to remove the rings is difficult. I ran
a water line to wifes honey house from the water heater and these suckers hold. The old brass fittings with screw type 'worm' clamps are obsolete in my book.
90% of my trailer build project came from PPL in Texas. great parts inventory and pricing is nice.
