RE_Todd's avatar
RE_Todd
Replacing a fridge
My wife and I are starting to look at Class A's for when we fully retire, and as I was going through the forum I pondered this question. For the Class A's with a residential fridge, how do you get it swapped out if it dies? I don't think it'll go through the door!!
  • How do aliens get residential fridges inside their spaceships...:h...their doors are smaller than the motorhome ones...:B.....Dennis
  • Roadpilot wrote:
    Many MH's have outside access ports so the compressor can be changed without even pulling it out. If they have to be replaced it's either the door, the side window or the front window.
    They require us to pull the refer when they replace a compressor on Residential refers. They will NOT even work on them until they are pulled unless it is a inside touchpad type problem under warranty. Doug
