- TvovExplorer II
Clamrobot wrote:
I will find out if my sink goes to BW tank. Yes, I have used a composting toilet for about 3.5 months up in alaska,it worked just fine as long as you divert the urine into a separate container. Used with one other person it for 1.5 months before having to empty it. The waste just comes out looking/smelling of dirt.
Just to clarify, did you use the composting toilet in an enclosed living area - like a camper? Most all composting systems I've encountered smell eventually. If it is in a room off to the side or at then end of a house it is fine, but to have it basically right where you are living may not be ideal.
I am very curious, if you do this, how it works out! Keep us updated. - TodduptonExplorerAlso not sure about adding more water capacity than holding tank capacity. If you have 100 gallons of water but only 50 gallons of storage in the gray then what can you do with the other 50 gallons? You would have to dump it to keep using your other 50 or use the outside shower a lot.
- guthriezExplorerFYI, the "Gone with the Wynns" couple put a composting toilet into their motorhome a few years ago. Might want to check their website for further info..
- braindead0ExplorerYou may need a new pump if your existing FW tank is not below the floor at roughly the same level as the existing black tank. Also if you replace with a FW tank that sits lower then the pump pickup, might be a problem.
Resale value will likely be very poor without a black tank. If you can swap in a FW tank without making heavy modifications so that the black could go back in.. that would be good I think. - tatestExplorer IIOn a Pace Arrow you will have to see if the tanks are accessible for replacement. Fleetwood went through a period in which they installed the tanks under the floor, atop the chassis framerails, in an enclosed heated space, for their "basement model" motorhomes. I've encountered this in Bounders and Stormies, have not dug into a '90s Pace Arrow.
- Mr_Mark1Explorer
^^^^^^ this makes so much sense to me. Keeping the 'fresh' and 'holding' tanks near the same size would allow for boondocking off the grid longer and would match the fresh tank (mostly).
Having three times the fresh water capacity vs. holding tank capacity would make you have to dump the 'holding tank' more often.
Safe travels,
MM. - dave17352ExplorerSounds like a good cleaning and some sterilization and your tank is all ready installed. :)
- coolmom42Explorer II
Dale.Traveling wrote:
Easy project. The hardest part is finding a ready made tank to fit the space the black tank has. Probably the simplest way to transfer water would be using a portable pump when needed. And also use the pump to fill the tank. If you find one with the same foot print it would also be a back up to the primary. Just try and stay with a tank of the same water volume as the original black tank for weight considerations.
An alternative to consider would be to just leave the tank in place, seal the opening for original toilet and cross connect the two waste tanks increasing the gray water holding capacity. Easy enough to carry extra water externally while dumping, even gray water, anywhere other than at an approved facility can get you into trouble.
As far as when the day comes to sell the modified coach I wouldn't worry as long as you're considering do the mod to the 1992 Pace Arrow in your forum signature. Now if the coach was a 2012 may not the best idea considering your target buying audience would be a pretty small focus group.
The is what I would do, and am seriously considering it. - supercubExplorerLike the above post suggested, go to Gone with the Wynns website. They've been using composting toilets for years in their RV's, they now have a sailboat and have them in it too. They have videos on installation, and what they did with their black tank. Lots of useful info on their website, might take a little looking, but it's there.
38,705 PostsLatest Activity: Jan 14, 2025
