DSDP_Don
May 22, 2016Explorer
"drwwicks".....If you look at the tile in your entry, I'm guessing you'll see that it sits higher than the carpet. The carpet will usually meet it because of padding and the thickness of the carpet, but is usually ramped up some. The problem is that they typically use something like "wonderboard" under the tile to keep it from cracking, where your carpet is stapled down to the plywood floor.
To stabilize the tile you would have to add the wonderboard, which will create a height issue with your slides. Your best bet might be to find some linoleum that looks like tile. There is some pretty nice stuff out there that looks like tile.
