wa8yxm
Aug 14, 2014Explorer III
That is why I ask how you knew the bypass was bad and suggested the check valve.
Glad you got it fixed.. I have a 3-valve system, no check valve.
Another issue I do not have.... I read about folks who use the cut off valve on the shower head (or another they installed as I did) to conserve water in the shower complaining about how it's all cold when they restore flow.
Same valve is the cause I suspect. At very low flow rates there is not enough pressure to open the valve, so the line from the mixing valve to the shower head.. Fills with cold water only.
38,766 PostsLatest Activity: Jan 10, 2026
