mfox20
Nov 02, 2015Explorer
jhilley wrote:mfox20 wrote:whem2fish wrote:
mfox did you use Ray's?
I used Fort Worth Champion Spring in downtown Fort Worth. I have used them on 2 Class A's with good results for spring work, front end alignment and they did the labor on my shock replacement.
What did it cost?
It was about 700.00 for the spring work on each motorhome. Really made a handling difference when you took out the lean. Was worth the effort.
And you kinda have to know what is causing the lean. Older 94 was leaning hard right on the front but it turned out to be a weak rear spring. Current one was leaning on front and rear right side and was also just a weak rear causing the problem.
